Inventor General Discussion
Valued Contributor hlo
Valued Contributor
hlo
Message 1 of 5 (204 Views)
Accepted Solution
Tube design with loft
204 Views, 4 Replies
11-02-2013 12:27 AM
HI
Need some help, how to make this tube with the loft command, it need to be round all along
and not flatting is out
Regards
Henrik
*Expert Elite*
JDMather
Message 2 of 5 (193 Views)
Re: Tube design with loft
11-02-2013 03:23 AM in reply to: hlo
hlo wrote:
...., how to make this tube with the loft command
Shouldn't that be a Sweep rather than a Loft?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
Cadmanto
Message 3 of 5 (181 Views)
11-02-2013 04:51 AM in reply to: hlo
Henrik,
If you do searches on Youtube you will see plenty of tutorials on how to create these types of features.
Basically if you are doing a straight feature that has change between the base and the top then you need to use the loft feature.
If you have to create a snake type feature that may change shape along the curved path then you need to create a swepted feature.
I hope this helps you and good luck.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Valued Contributor
hlo
Message 4 of 5 (171 Views)
11-02-2013 05:20 AM in reply to: Cadmanto
HI both
Thanks for quick replay, I know about the sweep, but not that loft
Can’t do this type.
Regards
Henrik
*Expert Elite*
JDMather
Message 5 of 5 (161 Views)
11-02-2013 06:15 AM in reply to: hlo
Can’t do this type.
Here is a Loft solution.
Announcements
Need installation help?
