Inventor General Discussion
*Expert Elite*
-niels-
Message 1 of 4 (256 Views)
Tube & Pipe Route turns back on itself
256 Views, 3 Replies
02-06-2013 05:07 AM
I'm having a strange problem with a flexible hose route, as the title says the route is "turning back on itself".
See image "route_problem" for a close up in the actual machine and "route_problem2" for a view of the route on its own with an indication of how it should be.
The strange part is that in the first run (the one ending in ".gesloten") everything worked fine and as expected, but in this new run it's behaving as seen in the images.
If i make a new route in the ".gesloten" run then it works normally again but in the other run it won't.
Does anyone have any idea what could be going on here or any suggestions on how to fix this?
Using IV2014 Pro SP2 - upd.1, Win7-64bit
*Expert Elite*
cbenner
Message 2 of 4 (241 Views)
Re: Tube & Pipe Route turns back on itself
02-06-2013 08:10 AM in reply to: -niels-
I don't suppose you could post the actual files here,.. or something similar that duplicates the error?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
*Expert Elite*
-niels-
Message 3 of 4 (225 Views)
02-06-2013 11:31 PM in reply to: cbenner
Seeing as the hoses are added at the top level assembly, which is the entire machine, i can't add the files.
I tried duplicating the problem in a smaller simplified assembly, but i couldn't get the same problem to show.
Which leads me to believe there might be something "broken" in my original file...
(also, even if i could recreate the problem, i'm unsure how to attach my custom hose and fitting content libraries...)
*Expert Elite*
-niels-
Message 4 of 4 (216 Views)
02-07-2013 05:57 AM in reply to: -niels-
I decided to start over and i copied the first (working) run into my new T&P assembly.
Creating the 2nd (".open") run in the new file doesn't give me any problems, so i'm just gonna continue from here.
I'll try to attach a pack-n-go from just the T&P assembly with the ".gesloten" and ".open" runs so people can have a look at that at least, even though it's missing all the connections and routing workpoints.
(the files are 13mb altogether, around 10mb zipped, so i need a place to upload them)
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
