Hello everyone!
I work at a small manufacturing company with only 2 engineers using Inventor and so far we have only been designing locally on our computers, ie no vault or server based file storage.
What we would like to do is move to a shared file system on our company's shared network folder. We would then set our inventor "Project location" to Z:\CAD_Files or something similar, where Z:\ is the shared network drive. Moving all of our parts and assemblies shouldn't be an issue, but I am concerned with how to use Content Center (CC).
Right now, if any of us "Place from CC" the default storage location is something like C:\Users\Paul\Documents\Inventor\Content Center Files\R2014
Current Project information
I've read on this forum to think of CC as holding the "ingredients" to make parts, which when Placed in an assembly become parts stored in the file path above.
QUESTIONS
-If we set the Project to have a default Content Center location of Z:\CAD_files\Content_Center, will Inventor be able to open the network stored assemblies if the CC child parts are using "ingredients" from our local computers?
-How do we move the CC "kitchen" to the shared folder?
I'm sorry if this is a confusing way to phrase my question but we are still learning over here. Thanks in advance for any help!
I've never worked with Desktop Content Center, always Vault so take this for what it is worth... but I believe that if you set your Project to a shared CC location, and then also in your Application Options set the location of your Content Libraries to that shared location, as well as your Default Content Center files path... it should work. The problem I see may be in all of the CC parts you both have already generated, which live on your local hard drives. These would need to be reconciled to the shared location without creating duplicates, or overwriting anything custom either of you may have don in your own CC.
Then there will be the inevitable unresolved referense errors you will get as you open old assemblies which are looking for CC parts originally placed form your local CC.
IOW... expect a few hiccups along the way and make sure you have great backups!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi PAULBIELA6426,
I think you're close to having it. Here we use the Desktop Content libraries, but we put those on the network. So I would recommend these steps to get this set up:
This will give you the CC Libraries (recipes) and the CC Files (finished baked goods) all on the network where everyone can use the same files. This is how I currently have things set up, and it works well.
Edit: Just to clarify, most of what I typed is what cbenner and blair have said, I was just slow about getting this posted.
I hope this helps.
Curtis
And as usual, Curtis, very detailed and easy to follow... kudos my friend.
Chris Benner
Wow thanks for all the responses! I'm going to mess around with these suggestions and 'll post back here if I have any other questions.
Thanks again!
