I've tried this code here after setting the assmebly flexible in the top level but it doesn't work. Maybe i'm doing something wrong????
ThisApplication.ActiveDocument.ComponentDefinition?.RepresentationsManager.PositionalRepresentations(?"Test").Activate
I will be pulling the subassemblies in as read-only parts and I would like to change the postional representation with code in the top level assembly. Is this possible?
Hi MAC30,
I'm not sure I understand what you're attempting to do (change the representation? or place the subassembly using a representation?), but it looks like maybe you're trying to do this with iLogic and not VBA?
If so firstly, be sure that you really need to use code for this:
Secondly, see this link for an example for changing the Positional Representation via iLogic:
http://forums.autodesk.com/t5/Autodesk-Inventor/pos-rep-view-rep-and-ilogic/m-p/3372543#M428673
I hope this helps.
Curtis
I have a subassembly (subA) that will be used in different top level assemblies, and will have multiple veiws for both those assemblies. Ex
Assembly 1
SubA
SubB (reps 1 and 2) depending on excel paramenters
SubC
Direfferent assembly also uses SubA
Assembly 2
SubA (reps 1, 3 &4) depending on excel parameters
SubD
SubE
SubA will be in a standard directory that I will not have write access to. I want to create 4 different positional reps and show the correct rep in the top level assemblies based on the parameter values.
The only file I will have open is the top_level assembly, which will have SubA in it set to the "master" rep, but after I update my excel parameter sheet I want the correct position rep of SubA to be shown in the assembly. I will not be adding position reps to the top level assembly.
Is this possibly?
To make things simple, I'd like to be able to change the Positional Rep of an subassembly by using ILogic in the assembly it is placed in. Sort of like the IPart Change row, but I'm just wanting to change the Positional rep.
Hi MAC30,
I started looking into this yesterday afternoon and I think you'll want to use the SetPositionalRepresentationOverride method on the subassembly component occurrence to do this. Also, I think you might need to have a positional representation at the top level assembly in order to set the subassembly postional override.
Do you have some code started? If so it might be helpful to share what you have so far.
Also just as a tip, since your request involves the Inventor API, you might have better luck searching and asking this type question on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
