Kent,
Thanks for the hint.
I finally found the solution using your comment.
I went in Drafting standards, common tab and I edit the break lines, but instead of the linetype, I turned the color to white. So the break lines appear in white and there are not printed.
This is working with a 17x11 HP printer. Don't know if this will work with a pen plotter.
Thanks to all
Danielg
