1. Open the attached ipt.
2. "Edit" sketch 1
3. Click the "Look At" Icon
4. Select the Horizontal Line
5. Mouse over any line. Will probably highlite.
6. Add a angular dimension between the vertical and diagnal line (should 115 degrees)
7. Mouse over horizontal or vertical line.
- 7.1 Do they highlite?
Add a dimension to the horizontal or vertical line by clicking on the line.
- 7.2 Can you do it?
The answer to 7.1 and 7.2 in my case is NO!!!
8. Slightly rotate the sketch.
9. Mouse over horizontal or vertical line.
- 9.1 Do they highlite?
- 9.2 Can you do it?
The answer to 9.1 and 9.2 in my case is YES!!!
Whats going on here?????
I have tried this on two different machines with two different processors and two different graphic cards with the same results. If your results are different, I would sure like to know why?
Don A 🙂
