Hi I'm creating a bottle using inventor and I am trying to make it hollow by using the shell tool. However, when i try to select the top of the extrusion (neck of the bottle) it wont let me. Instead it will only select the bottle as a whole and just ends up getting rid of the whole thing! any help would be much appreciated! thank you!
Hi! The behavior sounds geometry-specific. Please attach the part you are working on or send it to me directly (johnson.shiue@autodesk.com). I would like to understand this issue better.
Thanks!
My guess is that you have tangent faces.
Uncheck the Automatic Face Chain option and see if it works as expected.
