Inventor Forum
Trouble Creating Flat Pattern View
8 REPLIES 8
Message 1 of 9
bachxuanguyen
835 Views, 8 Replies
I just recently got into Inventor, it is a very new program for me. I'm having problem unfolding this part, I been searching for solution but was unsuccessful even though there are many results out there.
I'm created the parts successfuly with no error, but when I try to create a flatten view it kept giving me error. I notice that some people try to use chamfer to resolve this issue but I tried with no luck. Also, I play around with the gap size and still get the error. Maybe someone here could help me out and and create the flat view for me so I could learn how to do it.
Thank you,
Bach
Inventor 2011
Window 7, 64bits
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: bachxuanguyen
I noticed that your first sketch isn't constrained.
You might start here http://home.pct.edu/~jmather/skillsusa%20university.pdf
I would not have used Extrude.
Most of work down to Corner4 could have been done with a single Contoured Flange feature.
I will try to post example in the next couple of days if someone else doesn't contribute a solution.
Message 3 of 9
Thank you, I will wait for your version of this part. It is alway better to see other's method and also I want to see the most efficient way to create parts similar to this.
I had look into that PDF before, I found it while surfing. I will look into that constraint.
Best Regards,
Bach
Inventor 2011
Window 7, 64bits
Message 4 of 9
M.Peppel
Hi Bach,
your part does not unfold decause of the way you cut the notches 5;6; 9;10. The way they have been made you created an edge that does not allow the part to be unfolded.
HTH
Matthias
Nihil Ex Nihilo
Message 5 of 9
M.Peppel
in reply to: M.Peppel
Hi Bach,
to prevent the problem described above you should better use the proper corner option from the flange dialogue (see screenshot).
Cheers
Matthias
Nihil Ex Nihilo
Message 6 of 9
bachxuanguyen
M. Peppel,
I was playing with it this morning and using the unfold button, I was able to unfold everything except the flanges with the round corner.
Right now, I played around with the corner gap size at 0.1, round; and hopefully get something to work, so right now I keep playing with it and see if I can fix it.
Thanks for the replies,
Bach
Inventor 2011
Window 7, 64bits
Message 7 of 9
JDMather
If the radius of the round corner cuts is not important and the angle of the chamfers not critical - this is one easy solution.
I have another solution if those angles and radii are critical.
Message 8 of 9
Thanks JD Mather, I couldn't open your drawing, I have Inventor 2011.
I remake the part using fold/unfold technique. It's a little bit longer but it work,  I was able to fold out everything.
Here is the new drawing I made. Looking through my steps, what other methods would you suggest to reduce the steps.
Best Regards,
Bach
Inventor 2011
Window 7, 64bits
Message 9 of 9
JDMather
You should put 2011 in your signature so that everyone knows.
I will try to post a step-by-step when I get a chance.
But you can see my feature tree from this image
