HI:
I have the attached 2011 inventor structure model which require trimming the edge of surface outside the boundary structure plate in preparation for FEA analysis.
I was trying to use "delete" surface for the above ans found that after deleting the outside surface there is a gap in the boundary plate and unsure if this will affect the FEA modelling?
thanks,
Martin
You can use the split command, if i have undestood
Admaiora
@mmok wrote:
I was trying to use "delete" surface for the above ans found that after deleting the outside surface there is a gap....
I assume you meant Delete Face command. Be sure to use the Heal option of that command or you will change your solid body into a surface body.
There is most likely a much easier way.
I would model this quite differently.
See attached for what I am trying achieve.
Being a new comer I am open to all suggestion on how use the tools better, you mentioned that you would model this differently and will you be kindly to run me through on the approach this?
thks,
HI Carlos:
See attached on what am I trying to achieve.
thks,
Martin
Hi!
Create a pane by these three points:
Then Open Split Tool.
Select "Trim solid" Mode, and choose the plane as boundary. The arrows point to the Trimmed material.
Use the same for the rest of your solid.
The key is in the boundaries (surfaces) you need.
You ca have boundaries formed by planes, surfaces made by extrusions, sweeps, etc, and you also can copy faces in the model and repair them to serve as boundary.
Carlos:
Much appreciated for this, I will have a go accroding to your tips and come back if there's more question!
thks,
Martin
Carlos; you method did work very well! just one more trimming need to be done (see attached) where it require two interacting surface to trim the boundary plate, do you have any suggestion as if I am trimming the plate through those two surface (pointed in red arrow in the attached) some part of the model will be loss.
Going forward I will require to take this model for FEA, do you have any experience in this area where you can give me a few pointers on how to check and prepare the model for meshing process? my understanding is that if there is any fault in the model it will interrupt the meshing process, since my model do have a log of connection between different plate I concerned it will causing problem somewhere in the mesh.
Many thanks,
Martin
