Hello Team,
I am having an issue with transparent parts in an assembly, some of them seem to be in a transparent mode, i can't make them solids, the assembly is an import from CATIA, I am not sure if that is the reason of the transparency, I want to have the solid in the assembly, and the second issue is that when i want to make a drawing for that assembly, there is one part that is missing, it appears in the assembly but not in the drawing, please help me, I wou appreciate a lot!!!
Thanks!!
Because they are surfaces instead of solids.
You can try close the surfaces during import. So... before open *.CATProduct go to Options and check the Auto Stitch and Promote maybe Inventor can close the surfaces in solids.
Attach the original file here if you have trouble getting it converted to solids.
Indicate what version of Inventor you are using.
The CADWhisperer YouTube Channel
