Try copying the MDT file to your local hard disk. Set your Inventor project to so that the workspace is the same folder as the MDT
file.
In the translation destination set that to the same folder.
If it works, you may have an issue with network privelidges. If it still doesn't work, you do not have sufficient privelidges on
certain folders on your local machine (basically Change permission on C:\Program Files).
If you log in as administrator does it work?
I have had numerous issues with this, and the saga is ongoing...
John Bilton
