Going through the iLogic tutorial I have a part called "bracket" which has a multi-value parameter "mass" which can be 100, 200, 300, or 400 and controls the width of the bracket.
I have an assembly into which I have placed thee brackets.
How do I set different parameters for each of the instances of "bracket"? I want one bracket with mass = 100, one with mass = 200, and one with mass = 300, such that I have three brackets of different widths.
Sorry this is such a newbie question, but somehow I can't figure it out, and I must not be searching on the right text in Google because I find only ways to change the value of the parameter within the core component (such that all brackets change and end up the same width).
Sketch1 is not constrained or placed at a logical location in reference to the origin.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
before moving on to topics like iLogic.
If you are complaining about the bracket, it is taken directly from the Autodesk tutorial. All I did was place it in an assembly.
Or are you saying I cannot change parameters on components unless the sketch is in a particular location?!?
@Anonymous wrote:
If you are complaining about the bracket, it is taken directly from the Autodesk tutorial...
That figures. I don't know who writes this stuff - but they need to learn the basics.
I will take a look at your actual problem when I get a chance (do you have a link to the tutorial so that I don't have to search for it myself?
I went through this tutorial:
http://wikihelp.autodesk.com/Inventor/enu/2014/Help/0082-Tutorial82/0083-Inventor83/0234-iLogic_B234
Then I created a new assembly and placed the part into the assembly three times. Now I'd like to change the parameters of the components independently.
Note that my assembly is purely an attempt to learn how to manipulate instance parameters and does not represent an actual design.
Does nobody know how to do this? Surely this is a very simple thing...?
I'm surprised I can't right-click on a component instance in the browser and have an option to edit User Parameters on just that component.
I have a part where a feature is controlled (suppressed or activated) in iLogic by a User Parameter (a multi-value text parameter that can be either "active" or "not_active").
I have an assembly into which I have placed two component instances of the part.
I would like to change the User Parameter on one of the component instances to "active" and the same User Parameter on the other component instance to "non_active".
I'm asking if it's possible to have two components of one part with different User Parameters. If the answer is no, then what is the purpose of the bracket in this tutorial?
It is presented as an example of how you can program the behavior of a part using iLogic such that there are a number of User Parameters that can be set in order to select the appropriate bracket for a given load, whether or not you want chamfers on the corners, whether or not it should have a mounting hole in one, both, or no sides, etc.
What you are suggesting is that once I place one of these brackets in an assembly and set its parameters to be appropriate for that given load / chamfers / holes, I can never again use this part in another assembly unless I am willing to use the exact same version (re: load / chamfers / holes) as in the first assembly.
Why would anyone go to the trouble of programming the variations of a part through iLogic if you can only ever use one version of the part?
Or what am I missing?
Ok, I understand.
I think the Autodesk tutorial is kind of misleading, suggesting you can build a single part and use it for multiple applications. When in reality you build the one part, code up all the variations in iLogic, and then go through all of the variations, clicking "Save as" for each one so that you can actually use them in the future.
Thanks for clarifying this mrattray
@Anonymous wrote:... go through all of the variations, clicking "Save as" for each one so that you can actually use them in the future.
iParts may be more suitable for what you just described. If you haven't already, look into iParts to see if they can help you get what you need.
But no, a single part file can only have one configuration at a time. iLogic can program the part to take many different forms depending on user input, but it can only be one of those at a time. Component occurrences of the same part file in an assembly are identical copies of each other.
You have a little more flexibility with (sub)assemblies as component occurrences inside another assembly. You can have a single assembly file shown in different configurations (to an extent) through the use of view representations and positional representations. But not with part files.
Cameron Whetten
Inventor 2014
Just to elaborate - when you create an iPart when you place it into an assembly Inventor asks you for the configuration of the part you want in the assembly. For each new configuration Inventor then automatically "manufactures" a new part from the master iPart. This used to be referred to the iPart Factory in earlier versions of Inventor.
A part like this could also be used as a template file for starting new parts from, rather than using Save As from an existing one each time. If I created a part like the one you're describing, that's probably how I would use it.
What JDMather describes is what I expected from a part parameterized with iLogic. Good to know this exists with iParts - I'll go through the iPart tutorials and help sections.
@Anonymous wrote:What JDMather describes....
This one is about as simple as it gets (can do much much more sophisticated use of iParts).
Start a new assembly.
Place Component and select this Die.ipt file.
A dialog box will pop up - examine the tabs.
Go back to the first tab and select the 3mm.
Also in Inventor right mouse button everything to find hidden functionality.
