Inventor Forum
Title Block
3 REPLIES 3
360 Views, 3 Replies
Title Block
Is there a way to keep a tally of how many times a title block is used in a drawing?
3 REPLIES 3
jletcher
If they are the same I think an ilogic code can count them not sure but just for me why would someone need this.
Never know may learn something new.
in reply to: jletcher
Long story short because of QA.
innovatenate
You may try some iLogic code like the following. This code prints out the name of the Title Block used on each sheet.
iLogic Code:
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oDrgDoc As DrawingDocument = oDoc
Dim oSheetCount As Integer = oDrgDoc.Sheets.Count
Dim msg As String()
ReDim msg(oSheetCount)
Dim i As Integer
For i = 1 To oSheetCount
    msg(i)= oDrgDoc.Sheets(i).TitleBlock.Name
    msgString = msgString & Chr(13) & "Sheet " & i & "" & msg(i)
Next
MsgBox (msgString, ,"TitleBlocks Used")
Nathan Chandler
Principal Specialist
