Anyone tried to place a dimension in an IDW, only to have it disappear?
Today, I was playing with a drawing that was doing this and discovered a
workaround. Start the dimension like you normally would but instead of
picking a random placement point for where the text goes, move the
cursor over another dimension until the little yellow dot appears then
move the cursor to a position where it is in line with the one you just
hovered over. You should see a little yellow dot as your are picking
the placement. The dimension should not disappear.
This process is normally used for lining up the dimensions but it seems
to keep the dimensions from disappearing. If you want, you can then
drag the dimension to a new location and it will remain visible.
