Solved by rdyson. Go to Solution.
Did you forget to attach a file?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
If you file/s won't attached try one of these
1) Check that Internet explore IS NOT in compatibility view and resend
OR
2) use GOOGLE CHROME to attached files ( this is usually the best option.
3) The file is to big zip it and try again.
From personal experience IE11 has some, well quite a few, compatibility problems with this and other sites as bid IE10 but most of those were fixed.
3 solutions
1. multi-body solids
2. derived components
3. edit in context of assembly and Copy Object surface for trimming.
Any one of the 3 techniques will work.
Which one of the three methods above (1, 2 or 3) do you want to have demonstrated with this assembly?
(technique #1 is the easiest for beginners)
