Hello Guys,
I have created ipart and has threaded future. The first part has UNC threads. How can i select different threads in the table?? i have attached the model for it.
Thanks in advance
Solved by CCarreiras. Go to Solution.
Solved by pball. Go to Solution.
Hi!
Just an idea... You can create in the model all the holes you need and use the supress options to have the correct hole in each row, supressing the other ones.
Regards.
It's pretty easy to change thread size in an Ipart. I'll post an ipart for SAE ports I've made and explain a little about it.
When authoring your ipart table you have to select the thread designation for the threaded hole you want to be able to change. Then you'll be able to use a different thread for each size of your part. Take a look at the attached ipart and if you have any more questions just ask and myself or someone else should be able to help out.
Hi
Like Pball says, its seems to be pretty easy!!! and better that my first idea to supress holes.
Im sending you a ipart instead the ifeauture, maybe it will be simply to you undesrtand.
Regards.
