Inventor Forum
Thread direction of holes in iLogic
3 REPLIES 3
fabian.vorpeil
458 Views, 3 Replies
Dear all,
I use the following code to get the information if a thread is right or left handed from an outer thread:
'Gewinderichtung Gewinde1
If Feature.InventorFeature("Bohrung1").HoleInfo.RightHanded = True Then
Gewinde1_Richtung = "RH"
'Else If Feature.InventorFeature("Bohrung1").HoleInfo.RightHanded = False  Then
'Gewinde1_Richtung = "LH"
'Else
Now I also need to get this information from a hole feature but I was not able to adapt the code correctly. The error I get says that "HoleInfo" for the type "HoleFeature" was not found.
Can anyone help?
Best regards and have a nice weekend
Fabian Vorpeil
3 REPLIES 3
-niels-
in reply to: fabian.vorpeil
From what i could find in the API help, you might have to look into the "HoleTapInfo" object.
I'm not that good with this stuff so i hope this helps...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
mrattray
Neils is correct. Tapped holes have a HoleTapInfo object, non-tapped holes have a HoleInfo object.
Mike (not Matt) Rattray
fabian.vorpeil
in reply to: mrattray
Thanks a lot guys, here's what I now use to get the thread direction:
If Feature.InventorFeature("Bohrung1").TapInfo.RightHanded = True Then
Else If Feature.InventorFeature("Bohrung1").TapInfo.RightHanded = False  Then
Else
 Have a nice weekend
