I apologize, I mis-read your post.
My response is relevent for THREAD features.
If you have a TAPPED HOLE feature, you can recover thread depth
automatically. You can do this at the style level, or by editing the hole
note. Just use the "Thread Depth Vlaue" variable token. See attached.
Andrew Faix
Product Designer - Inventor Drawing Manager
"Andrew Faix (Autodesk)"
wrote in message
news:4830702@discussion.autodesk.com...
No mechanism to recover this parameter explicitly. You can edit the text of
the thread note, and pull in the parameter in the text editor, or just
dimension it 🙂
Andrew Faix
wrote in message news:4830690@discussion.autodesk.com...
How can you display the thread depth of a hole when using the hole callout
function within an idw?
