Larry, I don't believe you answered the question regarding deleting the pink lines. I have the same problem with missing projected line references. Sometimes I can delete them, sometimes I can't. Am I missing something that lets me delete sometimes, like a filter that is on/off??
Joey
Attach your file here that exhibits this behavior.
You might have to right click and Break Link (or something to that effect) before you can delete.
(do you realize you posted to a 10-year old thread)?
I'm not sure if Larry still visits this forum.
I was reading 03 as 13 so ten years was a good point. i figured out that i could delete the projected scketch and that took care of removing the old lines
To delete projected lines (whether are pink or yellow):
-Select the line you want it removed
-A projection constrain will always appear when select these types of lines
-Select the constrain
-Hit the delete button.
-The pink/yellow line will turn green where you can either re-constrain or delete.
