Inventor General Discussion
Active Contributor
RDG3PO
Message 1 of 7 (211 Views)
Thickness as a property
211 Views, 6 Replies
12-13-2013 12:04 PM
I have an assembly in which the thickness of each of the layers in an assembly are generated from a part file that is split via a sketch. I use the Make Components tool to break the part into the individual layers, which also spits out an assembly.
Is there a way to push the thickness value of these parts that will update automatically if the thickness is changed in the parent part, in order to reference this property on the drawing?
INVENTOR 2014 STANDARD
IOSX and PARALLELS
Distinguished Mentor
rdyson
Message 2 of 7 (192 Views)
Re: Thickness as a property
12-13-2013 12:31 PM in reply to: RDG3PO
Yes.
Active Contributor
RDG3PO
Message 3 of 7 (143 Views)
12-16-2013 11:55 AM in reply to: rdyson
This helps, but I neet that parameter to report to a property, so I can get it to update in a view note that I place in the drawing.
IOSX and PARALLELS
rdyson
Message 4 of 7 (126 Views)
12-16-2013 01:39 PM in reply to: RDG3PO
Check export in parameters and it'll become a custom porperty in iprops.
Active Contributor
RDG3PO
Message 5 of 7 (98 Views)
12-17-2013 10:59 AM in reply to: rdyson
Thanks for your help, rdyson. I'm really close to solving this.
It looks like because the parts I'm trying to get a thickness from are made from a parent part, the thickness will not update when the thickness is changed in the parent part. Does this make sense?
IOSX and PARALLELS
rdyson
Message 6 of 7 (89 Views)
12-17-2013 12:11 PM in reply to: RDG3PO
Did you try manage> update>rebuild all?
Active Contributor
RDG3PO
Message 7 of 7 (82 Views)
12-17-2013 12:47 PM in reply to: rdyson
Yes I did. The model itself updates, but the parameter does not.
I attached the parent part, and the layer parts that come from it if you want to try and replicate the problem.
IOSX and PARALLELS
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
