We have had this issue for a while and using various workarounds, so today I decided to search for better solutions today. Searching through this forum and a few others, it looks like no one has asked about this topic in years, so I'm hoping that means Autodesk finally created a built in solution. However, when I try to get text from an unconsumed sketch layer to export with the flat pattern, the only thing that comes across is the text boundary box.
Am I missing a step somewhere? As many of the other threads have noted, I'm trying to get part numbers etched into parts. TXT does the trick, but manually adding it is a pain.
No updates.. Previously stated workarounds still apply.
Don't hold your breath..
Add the text in the cam program if possible.
I'd love to hear someone from Autodesk explain their reasoning. It has been a known problem for years and should be a simple fix. It gets frustrating when they continue to push "features" that most people don't want or need. I really wish that they would spend one year creating an IV release without the constant freezing, unexplained crashes, and fixes for the hundreds of needless workarounds that are required to use this software.
Good idea. I searched a bit and found that someone has already posted this. Unfortuneately, I was the first to vote for it. I've linked it below if you also have this problem and want to voice your support for a solution.
You can always wrap this up into an idea and post it in the Inventor IdeaStation.
Then attache this thread in the idea you post along with a link back to this thread.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I'm sorry, I don't understand what you are doing.
You have a part that you want text cut into, but when you export it the text doesn't export because you are just putting it in a sketch.
Is there some reason something cut into the part can not be cut into the model?
And how are you exporting?
Where do the bend lines and drill centers come from?
If there are holes or cuts that penetrate through the part, the profile of that shape goes in that layer. CNC cutting machines need two layers defined when cutting a part. The outer profile defines what is being kept. Anything in the inner profile is considered drop. That way the machine knows where to position lead ins and lead outs. You don't want a lead in or lead out burned into the final part.
That is probably clear as mud, so here is a mental picture example. Say you want to cut out a circle with a square cut out of the center of it. When you export the flat pattern, the circle would be placed in the outer profile layer and the square would be in the inner profile layer. When the file is imported into the G-Code software, it looks for the two layers. It would place a lead in on the outside of the circle and a lead in on the inside of the square. The square is considered "drop" or wasted material, so having a lead in there is not a problem.
There are some suggestions in this series of posts that might help:
