Inventor Forum
Text appearance bad in PDF exported out from IV 2014 IDW
10 REPLIES 10
Message 1 of 11
gcross
1360 Views, 10 Replies
The kerning of text in PDFs created by exporting out from Inventor IDW is way too close & looks terrible.
The font is Ariel with nothing special about it I know of.
I tried printing to PDF ( I have Acrobat) & it looks good,  text is WYSIWYG - no problem but PDF file is larger.
Is there a trick to exporting to PDF from Inventor to get WYSIWYG?
Gary
10 REPLIES 10
Message 2 of 11
akhidrosyidi
in reply to: gcross
are you sure use Arial?
try to check again, or try another font.
I don't have any problem with export to pdf,
or may you can use PDF printer to do this.
daily works with :
Autodesk Inventor Profesional 2014.
AutoCAD Mechanical 2014.
Autodesk Vault Profesional 2014.
Message 3 of 11
blair
in reply to: akhidrosyidi
Double check the font. If possible copy in the same font from another machine and see if that changes anything.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 11
Paul-Mason
in reply to: gcross
It may be the font,  I use nothing but Times New Roman and have no problems.
However it my be a setting with in Adobe it self, as this seem to be at least the second post where a user has had problems. Do you have these settings in Adobe ?
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 5 of 11
mercerc
in reply to: gcross
In your original post you mentioned you had Acrobat on your system. There is a know conflict when Acrobat is load on the same system as Inventor when export a idw as pdf. If you print through Acrobat how does it look?
Charlie M
Inventor Product Support Specialist
Message 6 of 11
mcgyvr
in reply to: mercerc
Can you explain more about this "known conflict"?
Message 7 of 11
jletcher
in reply to: gcross
You might laugh at me for saying this but make sure your print drivers are up to date. I had issues on one clients machine but after updating the print driver he had no more issues..
Message 8 of 11
Paul-Mason
in reply to: gcross
In all the year, at lest 10, that Ive been converting from IDW to PDF I've not had this problem.
I thinking on the lines of a third party program causing this problem.
Can you send me your test file so I can see waht results I get
I'd like to see this get solved as you neve know I might end up in this predicamane myself some time in the future.
Have you contacted Adobe about this ??
Inventor 2023 Pro
HP Z420 workstation
Message 9 of 11
gcross
It looks the same as on screen-bad.
The know conflict would explain it. This si the first I've heard of this-thank you.
Message 10 of 11
gcross
in reply to: Paul-Mason
Naturally , now it's not doing it anymore so it must have been a mystery poltergeist that's moved on. If it happens again I'll see if I can post something. Thanks
Gary
Message 11 of 11
gcross
My preferences look pretty much the same as yours except for monitor type so it' s probably not that.
Gary
