I agree, silkscreen stuff is just way more complicated than it needs to be with Inventor.
Most of mine could be done in sketches right in Inventor, but then you can't show them in
drawing views.
I currently bring a sat of the part into Acad, and do the silkscreen there. Then I plot
that to EPS, and also get a BMP of it for us in Inventor. Generally the bmp ends up
looking terrible In R8 there is more options for inserting graphics file types, but they
are all still bitmaps so I don't expect they are going to be that much better.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"rllthomas" wrote in message news:f19d7a5.1@WebX.maYIadrTaRb...
> Imagine if you will that you need to design some artwork in CorelDraw and show it in
your drawing. Lets assume it is important to you to be able to verify the edges of the
model coincide with the artwork such that you don't make a change and have silk screening
right over a cutout. It sure would be nice if you could insert a view sketch and have the
artwork's text and lines together. In fact, this is one of our biggest day to day
struggles with IV.
