Inventor General Discussion
Cadmanto
Message 1 of 10 (286 Views)
Text Notes in Drawing Views
286 Views, 9 Replies
01-03-2012 11:23 AM
Is there a way to associate a text string to a drawing view so when the view is moved
around the text goes with it and remains placed in accordance with the view?
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Curtis_Waguespack
Message 2 of 10 (285 Views)
Re: Text Notes in Drawing Views
01-03-2012 11:27 AM in reply to: Cadmanto
Hi Cadmanto,
Here's a tip on this:
http://inventortrenches.blogspot.com/2011/04/associate-text-note-with-drawing-view.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Cadmanto
Message 3 of 10 (282 Views)
01-03-2012 11:34 AM in reply to: Curtis_Waguespack
Curtis,
That is a great reference and I appreciate it, but the note I have that I want associated
is not linked to a custom property or needs to be.  It is just a label note.
In Solidworks as long as the view is highlighted if you add a text note it will automatically link
to the view.
Best Regards,
Scott McFadden
mcgyvr
Message 4 of 10 (277 Views)
01-03-2012 11:42 AM in reply to: Cadmanto
The tip from Curtis doesn't have to be a custom property.. It works the same with a regular "label note" as you call it. He just shows how to do it with properties too.
You can also do it by selecting a view and starting a sketch and placing the label note text in the sketch.. (but the leader method is faster)
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Curtis_Waguespack
Message 5 of 10 (276 Views)
Hi Cadmanto,
It's been a while since I've used Solidworks, but it sounds like this is easier to do in that program. In Inventor using the leader trick is the best way to create text associative to the view. Note that if it's just a static text note, you can just type it into the text box and then hide the leader, as described in the link.
The other way to do this is to select the view, and then create a sketch, and then create the text as part of the sketch. but I think this adds a "layer" that is not needed for simple text.
FYI: You can go to this link and request that the Inventor developers improve this if you'd like:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
I hope this helps.
Curtis
*Pro
ampster
Message 6 of 10 (275 Views)
01-03-2012 11:43 AM in reply to: Cadmanto
same thing applies to plain text, just delete the leader afterwards.
HTH
ugh, in the amount of time it took to look over the link and make my reply, a couple of people stated the same thing.
Cadmanto
Message 7 of 10 (256 Views)
01-03-2012 12:50 PM in reply to: Curtis_Waguespack
Thanks Curtis for the link.  I am sure that I will be having plenty of suggestions.
It is hard being very prolific in one software (i.e. Solidworks) and then switching to another.
But I am getting there.
I tried creating the text as part of the sketch and it still didn't link to the view.  Any chance you can post
a sample part/drawing file for me to evaluate?
Appreciate it.
Scott
Best Regards,
Scott McFadden
Cadmanto
Message 8 of 10 (254 Views)
01-03-2012 12:51 PM in reply to: mcgyvr
Thanks.  I am just going to have to keep working at this.  Haven't gotten it to work as of yet.
Scott
Best Regards,
Scott McFadden
mcgyvr
Message 9 of 10 (249 Views)
01-03-2012 01:06 PM in reply to: Cadmanto
Scott,
place your views in the drawing then click on the view you want your text associated to (a dotted rectangle should show up around the view) then press the "s" key. That will start the sketch being linked to that view.
Windows 7 64 bit
Cadmanto
Message 10 of 10 (207 Views)
02-07-2012 10:13 AM in reply to: mcgyvr
Thank you.  That worked like a charm!!!
Best Regards,
Scott McFadden
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
