Well I took the hit and got rid of my old XP machine and upgraded to a Dell Precision M6800 and Inventor 2014. I migrated to project I am work on and now I want to migrate my personalized part and assmebly templates. Where does Inventor 2014 store templates? There used to be a folder under 2009 titled templates. I can't locate such a folder in 2014.
Solved by jddickson. Go to Solution.
The template location is where you have them set within your 'project file'.
Thank you. I am sure I will have many more questions as I use 2014. So far I have just done a part. I had my main assembly open after migrating and the assembly and constraint features seemed quite a bit diffenren. But I will dive in and ask questions. Thanks again.
