Inventor Forum
Tell me why i can't insert a frame member.
2 REPLIES 2
1012 Views, 2 Replies
Try to generate a frame member. When it fails, tell me why.
2 REPLIES 2
Curtis_Waguespack
Hi rms390,
Please attach the required part files as well. Keep in mind that an assembly file is just an empty "bucket" into which you place other files and then assemble them.
It's also generally a good idea to state the version of Inventor you are using so that someone with Inventor 2013 does not work up a soloution for you that you could not access if you had Inventor 2012, for instance.
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Sorry this can be closed.  I checked it into and out of vault and then it magically started working.
