Hello Everybody and Autodesk,
Is there a way by which I can run a vba - macro over all the file in a folder using
Task scheduler,silently
Solved by bobvdd. Go to Solution.
Defining yourself a custom Task Scheduler task is probably the way you want to go, if you are not afraid of some programming
You might want to read my support blog article where I use iLogic rules in a custom task in Task Scheduler.
The same mechanism (with some extra work) can be used for running macros via a custom task.
Not sure what you mean with "silently". You don't want to bring up Inventor API and use Apprentice API instead , or you want to run Inventor in silent mode? Both can be done depending on teh actiosn you want to perform on the files.
Bob
Thanks Bob,
So far I am not afraid of programming not great at it though
but can do something which works for me Hope that stays that way.
I will look into the blog.
And yes Silent means in the background
Have a look at KwikBatchRun here http://kwikmcad.com/icode/KWiKBatchRun_64/KWiKBatchrun_64.aspx
I use it and it works great. Only $20 USD per seat. No affiliation, just a happy user of the program.
