Inventor Forum
Sweep along a curve
7 REPLIES 7
Message 1 of 8
JimSteinmeyer
448 Views, 7 Replies
Sweep along a curve
Good morning. I seem to be missing something in my sweep.I am attempting to create an eliptical end on a tank. Sketch 12 is the outer edge of the tank, this would be the path if I am correct. Sketch 13 as the profile returnd a message that it intersects the wire axie. Sketch 14 as the profile returns a self intersecting surface.
What is the correct step to take?
Thank you
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
7 REPLIES 7
Message 2 of 8
blair
in reply to: JimSteinmeyer
You profile shape has to change to follow this method. This would work fine if the tank was round but with an elliptical shape, your profile has to change as it follows the path.
I am thinking, possibly a Loft with three profiles, to get 1/2 of the shape and then mirror. You would need to edit Sketch 13 to be only 1/2 of the shape as your starting profile, Sketch 13 would be your mid profile shape and you would require Sketch 15 would be your ending profile and would be the other 1/2 of Sketch 12.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 8
JimSteinmeyer
in reply to: blair
Do I then leave it undiminished? Or is there a better way to allow it to follow the ellipse?
edit: removing dimensions gives me the same errors.
Jim
HP G71 notebook
Win 7 home premium
Message 4 of 8
blair
I edited my answer, possible using a Loft as the shape/profile needs to change.
Delta Tau Chi ΔΤΧ
Message 5 of 8
JDMather
Pretty easy to do as Loft (see attached).
Message 6 of 8
JimSteinmeyer
in reply to: blair
Will try that.
Jim
HP G71 notebook
Win 7 home premium
Message 7 of 8
Yep, I was using a screwdriver to turn a bolt. The loft is the feature I should have been using.
THank you Gentlemen.
Jim
HP G71 notebook
Win 7 home premium
Message 8 of 8
JimSteinmeyer
in reply to: JDMather
JD,
Can you explain to me why my model shows the sketch lines for the loft and your's doesn't. Other than you know what you are doing of course. Smiley Wink
Thank you
Jim
HP G71 notebook
Win 7 home premium
