Hello all
I have a strange and sometimes irritating issue.
Some of my parts are derived surface parts, I then create solids from the surfaces.
The problem I have is:
- The surfaces sometimes come through by default on my drawing views, I then have to track the offending part down and switch off the visibility of the surface
- On the odd occasion, I have not been able to switch off the surface visibility, and the only work around was to derive the derived part into a new part and use that.
Notes:
I am not sure if the surface visibility is switched off when placing the parts in the Assemblies. (Can't remember)
I work with tensile membrane structures, these surfaces are sometimes huge, with millions of individual triangles creating a mesh, depending on the size of the membrane, I will choose not to dislay the surface as Inventor cannot handle the calculations.
Is there a setting to have this switched off by default, I have perhaps missed?
Thanks.
Hi
Please explain the Delete body method, are you refering to a multi-bodied part ? If so, I use this method as well.
Below is a small example of my method of deriving a surface model.
But my derived surface cannot be deleted it would defeat the purpose of using the skeleton to be able to manipulate all of the parts. I create a skeleton and derive it into all of my parts to chabnge sizes and speed up copy design, it takes forever to turn iff the surface viz in the drawing views, and they show 8up no matter how careful I turn them off in the parts.
First off, make sure that you understand this: https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2017...
Second, I think it is a bug inside Inventor or an issue that I never fully figured out. Within the context of the assembly, you may be working inside of the part, turning surfaces off. Everything looks great as you back out to look at the assembly. You go to the drawing and insert the views of the assembly and now these surfaces reappear.
Instead of turning the surfaces off at the part level within the assembly, you must separately open the individual part and turn off the surface there. I don't know why this is and have never understood it.
Rob
Hi
I agree, definitely a bug. (well...maybe not)
My work around:
At a part level
switch off the visibility of the surfaces
create a view rep. (I don't bother changing the name, just hit the button.)
All that's left now is to remember to actually do it, as most times it only rears its ugly head during detailing, then I have to go back and "fix" the problem.
Something just occurred to me...
Looking at my screen at the moment, I am going to test creating the view rep in my template, as I am making an assumption that the view rep works the same as in the assembly environment, where the master is locked, thus making everything visible. So in other words, it's might not be a bug, just a mindset change ?
I will post back with results.
