Inventor General Discussion
Distinguished Contributor
ohunome
Message 1 of 8 (35 Views)
Sub-Assembly Problems
35 Views, 7 Replies
11-20-2002 03:16 AM
I have a spherical bearing (bearing in housing moves) in a sub assembly and when I bring it into the top level assembly it doesn't behave like it does in the sub-assembly. Why, Why, Why? I've used adaptivity and it is still treated as a solid static entity.
*Dotson, Sean
Message 2 of 8 (35 Views)
Re: Sub-Assembly Problems
11-20-2002 03:24 AM in reply to: ohunome
If you make the sub adaptive it should work.
See CF for an example.   Open TopLevel.iam.  The parts in it are
a sub.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
ohunome
Message 3 of 8 (35 Views)
Re:
11-20-2002 03:30 AM in reply to: ohunome
The adaptivity is for modify the part file not for allowing the spherical bearing to move freely in the housing. The bearing is in a housing and this makes up the sub-assembly.
*Dotson, Sean
Message 4 of 8 (35 Views)
Re:
11-20-2002 03:47 AM in reply to: ohunome
I don't understand what you are asking.  When
you make a sub adaptive it allows you to move the sub in the top level
assembly.  Adaptivity also is used for cross part
relationships.
Can you post your subassembly in CF and let me take
a look?
Sean Dotson, PE
...sleep is for the
weak..
The
the sub-assembly.
ohunome
Message 5 of 8 (35 Views)
Re:
11-20-2002 04:49 AM in reply to: ohunome
I'm not sure what CF is?
*Dotson, Sean
Message 6 of 8 (35 Views)
Re:
11-20-2002 05:14 AM in reply to: ohunome
from the weekly FAQ:
Do not post attachments in this group. You may post attachments in
the
CUSTOMER FILES newsgroup. Please move the end of part marker to the top
of
the file and/or zip the files to save space. You can find the customer
files
newsgroups here:
WEBBASED CF:
href="http://discussion.autodesk.com/WebX?14@67.Wd6TaaEbdXF^1@.ee940b5">http://discussion.autodesk....
NTTP
CF:
href="news://discussion.autodesk.com/autodesk.autocad.customer-files">news://discussion.autodesk.co...
Sean Dotson, PE
...sleep is for the
weak..
I'm
ohunome
Message 7 of 8 (35 Views)
Re:
11-20-2002 05:32 AM in reply to: ohunome
I have posted my problem in the other customer file newsgroup. Notice how I'm not able to use the 15 degree constraint and allow the assembly to be adaptive.
*Dotson, Sean
Message 8 of 8 (35 Views)
Re:
11-20-2002 05:49 AM in reply to: ohunome
wow that is one funky assy... not sure what is
going on there... I see lots of no-no's but I'm having trouble making it work as
well.  Let me try tonight or tomorrow AM and let me see if I can get it to
work.
Sean Dotson, PE
...sleep is for the
weak..
I
adaptive.
