When I save a part, I want the part number and the filename to be the same.
When I insert the custom iPart into my assembly, I have to tell it what the
filename is (ex. G3032-435-ab). The columns in my BOM are Item, Part
Number, Description and Qty. With a custom iPart, what will be shown in the
Part Number column is "Equal Leg Angle" (or whatever the iPart parent is
named), not the filename that I gave it.
I don't see an easy way to get everything that I want unless I have to
manually edit each part after it is created (bummer).
Any Suggestions?
"Sean Dotson" wrote in message
news:57368DB8EEA0317F64B8C410BE6496CF@in.WebX.maYIadrTaRb...
> Why not make it a custom iPart (to drive the length)? There are only a
> finite # of possible sizes for a standard channel. In fact I think
Charles
> might have one on his site.
> Sean Dotson, PE
> http://www.sdotson.com
> Check the Inventor FAQ for most common questions
> www.sdotson.com/faq.html
> "Kirk A." wrote in message
> news:26DB7B51BAFF7A9DFA88DE563D1664E7@in.WebX.maYIadrTaRb...
> > I use the excel driven structural shapes quite a bit. I need a way to
get
> > the chosen size to be writen to some property field that can be lilsted
in
> > the Parts List. For example, if I open the C Channel file, then edit
the
> > excel sheet and chose the C12x25, I would like this size to be written
to
> > the Description property field.
> > v6, sp2
> > WinXP Pro
> > P4, 2.8 Ghz, 1G
> > Gloria II-64
> > nVidia v6.13.10.4072
> > 1280x1024, 32 bit
