Inventor Forum
Structural memebers driven by excel
3 REPLIES 3
171 Views, 3 Replies
I use the excel driven structural shapes quite a bit. I need a way to get
the chosen size to be writen to some property field that can be lilsted in
the Parts List. For example, if I open the C Channel file, then edit the
excel sheet and chose the C12x25, I would like this size to be written to
the Description property field.
v6, sp2
WinXP Pro
P4, 2.8 Ghz, 1G
Gloria II-64
nVidia v6.13.10.4072
1280x1024, 32 bit
3 REPLIES 3
Why not make it a custom iPart (to drive the length)? There are only a
finite # of possible sizes for a standard channel. In fact I think Charles
might have one on his site.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kirk A." wrote in message
news:26DB7B51BAFF7A9DFA88DE563D1664E7@in.WebX.maYIadrTaRb...
> v6, sp2
> WinXP Pro
> P4, 2.8 Ghz, 1G
> Gloria II-64
> 1280x1024, 32 bit
When I save a part, I want the part number and the filename to be the same.
When I insert the custom iPart into my assembly, I have to tell it what the
filename is (ex. G3032-435-ab). The columns in my BOM are Item, Part
Number, Description and Qty. With a custom iPart, what will be shown in the
Part Number column is "Equal Leg Angle" (or whatever the iPart parent is
named), not the filename that I gave it.
I don't see an easy way to get everything that I want unless I have to
manually edit each part after it is created (bummer).
Any Suggestions?
"Sean Dotson" wrote in message
news:57368DB8EEA0317F64B8C410BE6496CF@in.WebX.maYIadrTaRb...
Charles
> Sean Dotson, PE
get
in
the
to
> > v6, sp2
> > WinXP Pro
> > P4, 2.8 Ghz, 1G
> > Gloria II-64
> > 1280x1024, 32 bit
Not so, a custom iPart will be given a name "Part1.ipt" and be placed in the
workspace if you don't specify a name and location upon insertion
K
