One of my designers found the following oddity with a simple contour flange in a sheet metal part:
She shared a sketch to "extrude" the contour flange with a different length in each direction (because there is no asymmetrical option for contour flanges--I will add this to the IdeaStation). It seemed to work fine at first, but whenever the "Height" parameter is changed, the second contour flange feature shifts to the right by a distance equal to the material thickness.
There is no conceivable reason that it should do this! The only way I have found to shift it back is to edit the second contour flange feature (right-click Contour Flange2 > Edit Feature > OK). But the bug re-appears whenever the Height parameter is edited.
This one has stumped me. I have attached the part (Inventor 2012). Can someone else try this to see if it is reproducible?
IV2012 Pro SP2 Update 3, Build 219; Vanilla Vault 2012, Update 2
Win 7 Pro 64-bit SP1; Intel Xeon Duo @2.40 GHz, 9 GB RAM,
NVIDIA Quadro 2000, 1024 MB GDDR5
Cameron Whetten
Inventor 2012
Solved by cwhetten. Go to Solution.
I should have waited a few more minutes before posting this! It turns out that the second feature needs to have a model edge selected for full definition:
Once an edge is selected, the feature works as it should.
Cameron Whetten
Inventor 2012
Here is the link to the IdeaStation for adding an option for asymmetric distance contour flanges:
Go and vote!
Cameron Whetten
Inventor 2012
