Inventor Forum
Stock Number not a searchable field in Vault?
1 REPLY 1
anderson51
300 Views, 1 Reply
I am trying to turn on the stock number field under customizable fields within vault, however stock number is not an option...has this always been the case?
Thanks for your time,
1 REPLY 1
cbenner
in reply to: anderson51
This is another one that should be in the Vault forum.  http://forums.autodesk.com/t5/Autodesk-Vault/bd-p/101
What version of Vault are you using,... what version of Inventor?
Stock Number in Vault is not a System Property.  It is a User Defined Property, even though it correlates to an iproperty.  This is actually true of a lot of iproperties.  You will have to create this property in your Vault, and map it to the file property depending on what end result you are after.
