Hi!
I am still encountering problems when trying to modify Appearance Library. I have the "update1" installed.
I used to have RAL colors in my Style Library in previous Inventor version. They were working just fine... I have converted these colors to 2013 Appearances. Now the problem is that the preview colors in Appearance drop-down menu are not shown as they should. Actually - the colors have no thumbnail at all.
This is what I have done and how it works:
1. I have created my own .adsklib file where I have imported the colors I'd like to have from the 2012 Style Library.
2. I have made some modifications to all color appearances. I have changed the thumbnail view as "Plane". While making these modifications, everything seems to be fine. I was forced to do this just to create the thumbnail with right color.
3. Creating a new part
4. I've added this existing, modified library to my appearances and / or to my project file.
3. If I double click the appearance to add the appearance to the document and edit it, it's displayed in "Document Appearances" just right; the color is right and also the "plane" thumbnail is displayed correctly. In the .adsklib browser the color thumbnail is not updated.
4. If I drag it back to the .adsklib from the document appearances, Inventor asks do I want to keep both appearances or replace the old one. I have selected that replace the old one.
5. Anyhow - if I want to change the color of the part or surface from the Appearance / Adjust drop-down menus, my colors are displayed without any thumbnail.
I would just like to see the preview for the color!
Can someone help me?
I have played with Inventor every day since 2000. I just love this program but now I have to say that this new Appearance library "thing" is something that makes me sick. It seems to be badly uncompleted with multiple bugs.
Thank you and sorry,
Marko Hannula
Senior Consultant
CAD-QUALITY FINLAND OY
Inventor trainer since 2000, Autodesk Approved Instructor, Autodesk Inventor Certified Professional etc, etc...
Marko,
Unfortunately this is an outstanding issue that still needs resolution; it's identified on the list for the next update. Right now, even with Update1, there is no way that you can get the correct thumbnails for custom appearances on the dropdown from the Quick Access Toolbar.
As you state, this does work properly in the context of the appearance browser & in the library & when they are applied to parts. All I can do right now, is confirm what you are seeing.
-Chris
Im seeing the same problem in 2016 PRO SP2. What is the solution?
Bump. Has anyone experienced this with custom appearances? How do i get the swatch to display in the QAT or in the body of the appearance browser?
