Inventor Forum
Step file into solid
5 REPLIES 5
Henrik_Lo
238 Views, 5 Replies
HI
How come, I cant transferee this step file into a solid, using the stitch command.
Regards
Henirk
Autodesk Product Design Suite Ultimate 2014
Windows7 pro 64-bit
Intel(R) Core(TM) I7-2720QM CPU @ 2.2GHZ
Memory 8GB
5 REPLIES 5
JDMather
in reply to: Henrik_Lo
There are a large number of missing surfaces - the assembly will have to be rebuilt or request a good file from the source.
Henrik_Lo
in reply to: JDMather
HI JDMather
Thanks for quick replay, ill tray to contact the source file designer.
regards
Henrik
WHolzwarth
You won't have much luck with it, because lots of missing faces. I can't believe, that such a bad file has been created out of Inventor 2013.
If you can't get a better base file, do that:
- Activate Construction environment
- Unstitch all faces and do a quality check (No errors in this case)
- Define new group (Group1)
- Move faces of the biggest sheet metal to this group
- Switch main group invisible
- Disable translucency of Group1
- Stitch 5 resulting faces
- Copy object as face
- Leave Construction environment
- In modeling environment, thicken whole combo 1,5 mm inwards
- Now back to CE and next faces
Well, some work is needed. But not hopeless with easy geometries like this.
Walter
Walter Holzwarth
Henrik_Lo
in reply to: WHolzwarth
HI
Ill hope for a better source file, but will tray this action task you describes
Thanks for helping
Regards
Henrik
WHolzwarth
Just noticing some other faces belonging to this initial folded part
Walter Holzwarth
