Inventor Forum
Spurious Offset Values are generated when simple edge to edge mates created
8 REPLIES 8
Message 1 of 9
2306 Views, 8 Replies
For some reason after using Inventor 2012 Professional,  When mating two flat edge surfaces together strange offsets with random values or distances are filled into the offset entry box and I have to then change the value to 0.00
This behavior started with no rhyme or reason.  The project is significant, and I'm at witts end trying to figure out what happened.  Even my backup master assembly files and previous versions are demonstrating this behaviour when trying to do a new constraint of any kind.  It even happens when working with a specific .iam when opening a sub-directory folder.
My project master assembly file is 1,620 kb in size and has hundreds of details and sub assemblies.
I'm pulling out my hair due to this sudden behaviour with the constraint issue and I'm to be meeting customers in a couple of weeks.
Any suggestions would be greatly appreciated.
Running 16 Gigs on a 64 bit I5-2500 CPU 3.3 GHz Windows 7
8 REPLIES 8
Message 2 of 9
mcgyvr
uncheck the "predict offset and orientation" check box in the constraint dialog. Should be right under the offset entry area... ruler looking icon with the mate icon next to it.
Message 3 of 9
swhite
As mcgyver stated make sure this box is unchecked, otherwise you get the default distance that already exists between the surfaces or constraint points.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Message 4 of 9
Many thanks to both of you McGyvr and SWhite,
I'm not sure if it was checked or not, But now it is unchecked for sure. THis is the first time such a troubling artifact has been a plague for since yesterday afternoon. I was build a few sub-assblys in a lower lever directory and it started acting up. last night, and the effects migrated to anything I performed on the master ".iam" drawing.
After making sure it was clear and creating a new sub-assembly and integrating it into the top level .iam The problem is now eliminated.
Many many thanks to you all.
Mike.EnvFlex
Message 5 of 9
JDMather
This is one of the few dialog box options that remain in the last used state.
Can be really aggrivating when you don't realize what is going on.
Message 6 of 9
in reply to: JDMather
Thank you, it is profound to have to wrestle with these gremlins and not knowing what they are and how to deal with them.
One frustrating item,  Is having to constantly go back and set perspective and shaded with edges in the View Panel any time you save a subordinate .iam in a lower folder and go back up to the master .iam and those associated actions.
Thank you again.
Message 7 of 9
swhite
Now and then it comes in handy when you have a part placed where you want but not constrained. Simply check the box and it will give the offset value automatically. Rarely use it, but get models from others sometimes with grounded parts, and makes constraining them easier. I only wish Frame generator and the use default name stayed in the last used state 🙂
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
Message 8 of 9
AndyWallace
in reply to: swhite
"This is one of the few dialog box options that remain in the last used state." Actually, it would be nice if Inventor remembered MORE settings, starting with the export-to-PDF settings! But that's another story. I noticed an odd behavior with this function today: predict-offset-mating from a surface to a line caused the part to shift along the line (perpendicular) while it was "thinking", causing the part to be misaligned after the offset stabilized. I haven't troubleshot why yet. Andy
Andy Wallace
Autodesk Inventor (2016) (3 years)
previously Solidworks (6 years)
Message 9 of 9
joshuawilliamsonAYFKM
y'all need to bury this "feature" in some other menu. this is not useful and is in it's trial stage of development at best. I accidentally checked it on and spent 2 hours today diagnosing the issue (and I see this "feature" as an issue). There's a part of me that wants to bill autodesk for my time on this one.
