Inventor Forum
Spring and constrainments
9 REPLIES 9
Message 1 of 10
vincentruhe
458 Views, 9 Replies
What is a good way to constrain a spring to a bolt.
In my disign i need a spring around a bolt, but i can't seem to constrain the spring to the bolt. I tried using the insert constrainment, but that also failed.
Any help would be greatly appreciated.
Kind regards.
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: vincentruhe
Attach your bolt and spring *.ipt files here.
The usual technique is with a Mate axis-to-axis and a tangent if no ground flat or a Mate if there is a ground flat.
What version of Inventor are you using?
Message 3 of 10
vincentruhe
in reply to: JDMather
I am using 2012 version
Message 4 of 10
JDMather
Attach your assembly here.
Only need the 2 parts you mention.
Message 5 of 10
vincentruhe
Will i be able to make use of the compression tool in the disign tab, if i use this sollution?
Message 6 of 10
admaiora
Hi Vincent,
here an example:
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 7 of 10
JDMather
You did not attach your bolt part file here?
Missing Bolt GB_T 5782 M3 x 20.ipt
Message 8 of 10
vincentruhe
Message 9 of 10
admaiora
Sure, compression command create a solid,  you can use constraints on it.
Admaiora
Message 10 of 10
vincentruhe
in reply to: admaiora
Thanks for the video! Help alot with some pictures and movies.
But why put that angle constrainment in?
