I'm using frame generator.
The design doctor indicates I have errors re splits have no effect. When I check the part I find several end conditions. Some times a red box and arrows shows up at one of the ends. I can redo an end condition with delete existing end conditions checked and it eliminates the extra end conditions. The red box and arrow stays behind. This does ot always hapen. Is there any way to delete the red box and arrow?
David E
I've seen this before, and there are several threads about it in here. But, I've never seen or heard of any good explanation of it or a good fix other than to delete the frame member and re-place it. I haven't run into it in a long time. It's one of those things that I'd love to see again so I could nail down the workflow that causes it... but by the time you see the red arrow, it's already too late.
Wish I could offer more guys!
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
My Blog, pretty weak I know, but I'm just getting started. 😄
http://cbennertipstricks.blogspot.com/
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
this for future reference
Just come across this issue in inventor 2013 after investigating the angles of the beams faces that had the error. I found angle to be 89.99 degrees and 90.1 instead of 90 degrees which was causing the error. The angle was being created by the frame 3d sketch point not being setup correctly.
