Inventor Forum
Spiral Flat Pattern
12 REPLIES 12
Message 1 of 13
aarmacost
2486 Views, 12 Replies
Spiral Flat Pattern
I'm trying to figure out how to get inventor to take a sheet metal spiral and flatten it out to create a flat pattern. Anyone have any suggestions? There are 3 seperate peices to this and need to creat patterns for each for fabrication.
12 REPLIES 12
Message 2 of 13
ampster401
in reply to: aarmacost
an assembly file by itself is useless, you will need to attach any part files related to this assy.
Message 3 of 13
aarmacost
in reply to: ampster401
Message 4 of 13
ampster401
2011 here, can't open them.
Message 5 of 13
blair
Try this method of creating the parts. Create a line, coil to a surface, thicken to get your solid body. Convert to a Sheet-Metal part, set the correct thickness in the Sheet-Metal set-up, and the part will flatten. Not sure how it will work on the angled item. You can't do 360 deg or rotation as you may end up with a self intersecting flat pattern.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 13
aarmacost
That works for the vertical peice on the outside, but not the two inside ones. Take a look at attached file, still will not flatten this one.
Message 7 of 13
aarmacost
And also I'm not sure what I did differently, but when i tried what you suggested, it didn't work for me...
Message 8 of 13
blair
You might have tried the flat pattern before you set up the thickness in the Sheet-Metal module. I went back to the folded item, deleted the flat pattern and created the flat pattern without any problems.
The flat floor portion is just a bunch of circles OD and ID with a cut from the outside to the inside. The sloped side I think is outside of Inventor. There are 3rd party add-in's that should be able to handle that type of bend/roll.
Delta Tau Chi ΔΤΧ
Message 9 of 13
aarmacost
in reply to: blair
What exactly do u mean by 3rd party add-ons? Is there something out there to create these patterns? Would really like to be able to make patterns to make spirals. I tried using a cone and triangulating the slope and it worked with paper, but when I went to make it out of sheet metal was just a disaster!! So any other help would be greatly appreciated.
Message 10 of 13
blair
Like this: http://partnerproducts.autodesk.com/compatiblewith/Autodesk_Inventor_2013_Certified_Products_Directo...
They are stand-alone software that works with Inventor files.
Delta Tau Chi ΔΤΧ
Message 11 of 13
jletcher
I have use SPI sheet metal software before and works great. And I do know it will do Strakes for stacks.
A strake is a spiral sheet metal used to help tall stacks.
Message 13 of 13
S_May
