I know how to tempererally sort parameters when opening the parameters menu in the tool bar but is there a way to sort parameters by name when accessing the prarameter list in an Ilogic rule or within a form?
I have an ilogic assembly and basically I have over 250 user parameters and I'm finding it increasingly frustrating at finding the parmater I require.
Have you set your parameters as Key parameters and use the Key filter to see only the most important parameters?
You cannot really filter in you iLogic rule. Unless you are able to create a VB code or add-in. But not in Inventor itself
Try creating a message box. Something in the line of:
If "Parameter" = "Value" Then MessageBox.Show("The value you entered is incorrect. Please add a value between 4 and 35 in increments of 4", "Wrong Value")
Just a suggestion.
