how can I get square tube as small as 1 inch in frame generator. The smallest I have is 1 1/4. Is there a content library that I can download that has smaller square tubing.
You can publish your own profiles to the Content Center for use in the Frame Generator.
The CADWhisperer YouTube Channel
Here's a start.
I totally understand and appreciate the ability to create custom shaped extrusions. However, I count no less than 27 sizes of square steel tubing smaller than 1 1/4" available right now from my steel supplier. Why does Inventor's library arbitrarily start at 1 1/4"? Expecting every user to custom make every COMMON size of extrusion is unfortunate on a CAD platform that is otherwise so amazing. This issue comes up often enough that I feel the need to set aside a LARGE chunk of my time to create a FULL library of steel extrusions smaller than what Inventor offers.
http://forums.autodesk.com/t5/Inventor-ETO-IdeaStation/idb-p/1231
Idea station post submitted. Please +1 it if you've had this problem:
http://forums.autodesk.com/t5/Inventor-IdeaStation/More-ANSI-sizes-in-Frame-Generator/idi-p/3752638
While I am more "concerned" about the lack of the common 1"x1" HSS in the CC, I would agree with you. Tubing/HSS sizes should start below 1.25". I would also say that creating custom structural parts for the CC is easier said than done if you want to include proper formatting for BOMS and partlists.
Rob
@Anonymous wrote:http://forums.autodesk.com/t5/Inventor-ETO-IdeaStation/idb-p/1231
JD, I think the link you want is Inventor IdeaStation not the ETO IdeaStation (whatever that is!).
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
