Inventor Forum
Sliver trimming
3 REPLIES 3
599 Views, 3 Replies
Sliver trimming
A coworker is making a punch and is trying to trim the corners off of the model.  As of yet, we have tried subtraction extrusions, subtraction lofts, sweeps, etc to attempt to remove the material from the corners of this punch.  There is a small sliver between the outside curvature of the profile corner and just inside that profile.  It simply needs to be trimmed in that profile, normal to the flat surface of the punch.  He tried larger sketched geometry and it subtracted just fine, but it will not remove the sliver.
The part was originally derived with the mold, but some changes had to be made to the punch part to allow for the forming.  I have tried to compress the part enough to upload it , but have not been able to get it below 5MB so I have attached pictures.  They get progressively closer, zooming in to the small area in picture PUNCH3 between the red and blue line that we are trying to remove.
Any help would be appreciated.
We are running similar but not exactly the same computers, but use the same IV11 on Windows 7 Professional 64bit.
3 REPLIES 3
JDMather
@Anonymous wrote:
   I have tried to compress the part enough to upload it , but have not been able to get it below 5MB so I have attached pictures.  .
Did you roll up the EOP before zipping to get the smallest filesize possible?
Find the red End of Part marker in the browser and drag to the top of the browser hiding all features from the graphics window.
Save the file with the EOP in a rolled up state.
In Windows Explorer right click on the filename and select Send to Compressed (zipped) Folder.
Is the resulting *.zip file still too large to attach here?
I can't really see the problem from the pictures - but my first thought is Delete Face with Heal option.
My second thought is to fix it in the Construction Environment.
Inventor 11 is a really old release and not supported as 64-bit - are you sure you aren't running Inventor 2011?
in reply to: JDMather
Sorry, yes it is 2011.
Didn't know about rolling up the EOP before zipping- thank you.  Here it is.
The sketch geometry he is trying to use is in Sketch 17.
JDMather
Well I took a quick look and didn't even get past the initial imported geometry.
It looks to my like it should be symmetrical but isn't.
And even if the design intent wasn't for symmetrical part - these faces still don't look good to me.
I would want to clean these up or get a clean model before going any further.
Edit: I healed the faces I was concerned about, shelled the 3.5 off and moved to origin.
see if anything can be done with attached.  (I got confused on what you are trying to trim off and the purpose of three consecutive Thickens of the same face.)
