Inventor General Discussion
*Myers, Ron
Message 1 of 8 (70 Views)
Sketchin in IDW view
70 Views, 7 Replies
10-31-2002 02:42 AM
It seems that I am unable to create a sketch in the drawing view. In 5 you
would select the view then select the sketch icon. This allows you to
contrain geometry to the existing view. Does not appear to be working.
Has anyone run across this?
Ron
*Myers, Ron
Message 2 of 8 (70 Views)
Re: Sketchin in IDW view
10-31-2002 02:47 AM in reply to: *Myers, Ron
Just to clarify,
It appears that any geometry added is getting associated with the view
because if I move the view afterwards, the geometry moves with it, however I
am unable to refer to any geometry for constraints during the view
creation.
Ron Myers
"Ron Myers" wrote in message
news:574471483202E0C2AEF1B414892D8B27@in.WebX.maYIadrTaRb...
you
> Ron
*Dotson, Sean
Message 3 of 8 (70 Views)
10-31-2002 02:48 AM in reply to: *Myers, Ron
I've found that it's more consistent if you pick the view in the browser
then hit sketch.
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
you
> Ron
*Dotson, Sean
Message 4 of 8 (70 Views)
Re:
10-31-2002 02:50 AM in reply to: *Myers, Ron
Use the project geometry tool
Sean Dotson, PE
news:smileyvery-happy:E470540B3DCD862472099C944F73BBB@in.WebX.maYIadrTaRb...
> Just to clarify,
I
> creation.
> Ron Myers
> you
> > Ron
*Myers, Ron
Message 5 of 8 (70 Views)
Re:
10-31-2002 02:55 AM in reply to: *Myers, Ron
That's it Sean, thanks they changed if from R5 as this was not previously
necessary.
"Sean Dotson" wrote in message
news:8099050F6C3A6CF6EEB0E78BEC8C9A39@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > Just to clarify,
however
> I
> > creation.
> > Ron Myers
5
> > you
working.
> > > Ron
*Myers, Ron
Message 6 of 8 (70 Views)
Re:
Yes, that is how I approach it as well.
Ron
news:36C9DD87379E921E77732F79E0C66EAD@in.WebX.maYIadrTaRb...
> then hit sketch.
> Sean Dotson, PE
> you
> > Ron
*Autodesk\
Message 7 of 8 (70 Views)
Re:
10-31-2002 09:22 PM in reply to: *Myers, Ron
All,
Just so everyone knows (I've seen this discussion before), if you go to
Application Options and the Sketch tab, and turn on "Autoproject edges
during curve creation", it will work as it did in previous releases. That
is, sketch on a view and you can constrain to the model geometry.
Just an FYI.
Rich Willis- Autodesk
news:3E9E7378B8CEC658617B0E8495C55C81@in.WebX.maYIadrTaRb...
> Ron
> > then hit sketch.
> > Sean Dotson, PE
5
> > you
working.
> > > Ron
*Myers, Ron
Message 8 of 8 (70 Views)
Re:
11-01-2002 12:24 AM in reply to: *Myers, Ron
Thanks Rich,
You are absolutely correct.
Ron Myers
"Rich Willis (Autodesk)" wrote in message
news:BC796D882C43F0B7007678A3FC7CFFC0@in.WebX.maYIadrTaRb...
> All,
> Just an FYI.
> > Ron
browser
> > > then hit sketch.
> > > Sean Dotson, PE
In
> 5
> > > you
to
> working.
> > > > Ron
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
