Thanks Rich,
You are absolutely correct.
Ron Myers
"Rich Willis (Autodesk)" wrote in message
news:BC796D882C43F0B7007678A3FC7CFFC0@in.WebX.maYIadrTaRb...
> All,
> Just so everyone knows (I've seen this discussion before), if you go to
> Application Options and the Sketch tab, and turn on "Autoproject edges
> during curve creation", it will work as it did in previous releases. That
> is, sketch on a view and you can constrain to the model geometry.
> Just an FYI.
> Rich Willis- Autodesk
> "Ron Myers" wrote in message
> news:3E9E7378B8CEC658617B0E8495C55C81@in.WebX.maYIadrTaRb...
> > Yes, that is how I approach it as well.
> > Ron
> > "Sean Dotson" wrote in message
> > news:36C9DD87379E921E77732F79E0C66EAD@in.WebX.maYIadrTaRb...
> > > I've found that it's more consistent if you pick the view in the
browser
> > > then hit sketch.
> > > Sean Dotson, PE
> > > http://www.sdotson.com
> > > remove all #s from email
> > > news:574471483202E0C2AEF1B414892D8B27@in.WebX.maYIadrTaRb...
> > > > It seems that I am unable to create a sketch in the drawing view.
In
> 5
> > > you
> > > > would select the view then select the sketch icon. This allows you
to
> > > > contrain geometry to the existing view. Does not appear to be
> working.
> > > > Has anyone run across this?
> > > > Ron
