Inventor General Discussion
Valued Contributor
Calavetta123
Message 1 of 7 (284 Views)
Sketch Symbols
284 Views, 6 Replies
10-28-2013 03:44 AM
Is there a way to update a symbol of one type, without the changes being applied to all symbols of that type in the drawing?
Example: If I have three Flag Note symbol's in my drawing from the same sketch symbol and the text reads 1, is there a way that I can change the text to read 2 in one of them without the other two flag notes updating as well?
IV 2012 Pro-Suite / VP 2011
Windows Vista Enterprise - 64 Bit
Precision Workstation T7500
Intel (R) Xeon (R) CPU - E5504 @ 2.00 GHz (8 CPUs)
12284 Mb Ram
Dual Quadro FX 5800
Cadmanto
Message 2 of 7 (270 Views)
Re: Sketch Symbols
10-28-2013 04:32 AM in reply to: Calavetta123
Need as little more information.  Are these symbols ones created in Autocad that you are importing into an Inventor drawing?  Or are they revision symbols or balloons from parts lists?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Valued Contributor
Calavetta123
Message 3 of 7 (256 Views)
Re: Sketch Symbols
10-28-2013 05:11 AM in reply to: Cadmanto
They were created in Inventor but are neither revision symbols or balloons from parts lists. It is being used for standard notes.
12284 Mb Ram
Dual Quadro FX 5800
Valued Mentor
stephengibson76
Message 4 of 7 (247 Views)
Re: Sketch Symbols
10-28-2013 05:23 AM in reply to: Calavetta123
edit the symbol, then saveas another name or put some prompted entry into the symbol
Stephen Gibson
View stephen gibson's profile on LinkedIn
Valued Contributor
Calavetta123
Message 5 of 7 (242 Views)
Re: Sketch Symbols
10-28-2013 05:28 AM in reply to: stephengibson76
Thanks, I thought of that but I was really hopeing to be able to edit the symbol instead of having a flag note symbol for each.
12284 Mb Ram
Dual Quadro FX 5800
Valued Mentor
stephengibson76
Message 6 of 7 (229 Views)
Re: Sketch Symbols
10-28-2013 06:34 AM in reply to: Calavetta123
prompt.PNGdo your flag note as a prompted entry, when you insert the symbol it will ask you for it or you can RMB on the symbol and edit it, each prompted entry can be different for the same symbol
Stephen Gibson
Valued Contributor
Calavetta123
Message 7 of 7 (224 Views)
Re: Sketch Symbols
10-28-2013 06:41 AM in reply to: stephengibson76
You Rock!! That is exactly what I needed it to do.
Robert
12284 Mb Ram
Dual Quadro FX 5800
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
