Inventor Forum
Sketch Collapse (lines becoming zero length)
3 REPLIES 3
mrattray
224 Views, 3 Replies
I opened a part today and noticed that it had collapsed into itself.
This should be a rectangle 85x15.75:
On closer inspection it appears that the vertical lines somehow became zero length lines. Why does this happen?
Edit: I should mention that I was able to repair the skecth by making the 85" dimension driven, then dragging the line over...
Mike (not Matt) Rattray
3 REPLIES 3
JDMather
in reply to: mrattray
I was able to repair the sketch by deleting the Vertical constraint (and then putting it back in again).
Very interesting.
But this brings up a question - why are you not using centerpoint rectangles?
And for many years I have recommended against horizontal and vertical midpoint constraints to constrain rectangles.
mrattray
in reply to: JDMather
@Anonymous wrote:
But this brings up a question - why are you using centerpoint rectangles?
I assume you mean "...why are you not using centerpoint rectangles?"
I originally drew this part before the feature was integrated into Inventor. If I was to draw it today, I would.
Is this why?
JDMather
@mrattray wrote:
Is this why?
No,  my reason was un-predictable results with sketch fillets or chamfers http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf , but now you have given me an example of another reason.
Back then centerpoint rectangle tool didn't even exist.
