How do you specify an angle for a line while sketching?
There is no command prompt like I've seen in so many examples etc.
Solved by CAG_DRAFT. Go to Solution.
Q1. What version of Inventor?
Q2. Have you made any changes to OOTB behavior?
Use the 'Tab' key to change the entry box focus from length to angle.
(select line, click once to start it, punch in some numbers for length, then press tab and set the angle you desire.)
