I've gone through a search, and scanned over the help file, and can not find this mentioned.
In my drawing, of either a part or an assembly, how do I display tangent lines?
Thank you, in advance, for your help.
Solved by blair. Go to Solution.
You need to select the Edit View, then on the Dispay Options is the Tangent Edges
Thank you. I am still flabbergasted that if you enter a search term like showing tangent edges in inventor help it does not show you the most basic of how to do something akin to what you just described.
