Inventor Forum
Showing Sketches in a Drawing of an iPart
4 REPLIES 4
CNewman
471 Views, 4 Replies
I've created a scroll on a face (using a 2D equation curve and the sweep command). I'm trying to add a centre line on the drawing to aid clarity (see attached image). It seems the Centerline Bisector command will not work so I tried to show the sketch using "Get Model Sketches" but this will not work either. Does anyone know if this command is available when the component is an iPart as this is? If not any other ideas on an easy way to show this.
Many Thanks
Autodesk Product Design Suite 2013
Win 7 Professional 32bit
Intel(R) Xeon(R) W3565 @ 3.2GHz QC
4.0 GB Ram
1GB Nvidia Quadro 2000
4 REPLIES 4
MarianHelcman
in reply to: CNewman
as far as I understand your request there is no way to create mid curve between two spirals.
Best regards,
Marian
CNewman
in reply to: MarianHelcman
Thanks for your reply Marian, my question was more aimed at showing sketches in the drawing though. It seems for an iPart member you cannot include any of the sketches in ta drawing of said part. Although it gives you the option to 'get model sketches' it would seem it doesn't allow you to view any of the sketches in the model tree to then include. I'm guessing this may just be another limitation of using iParts.
4.0 GB Ram
jacobEB
I am wondering about this as well.  Does anyone have an answer?
Jacob
sammybrugal
in reply to: jacobEB
Manage > Modify > Replace Model Reference. Then just select the parent part.
This should allow you to bring in the sketches from the ipart.
Have not tested this extensively, however.
Enjoy!
